uncle called up said the clutch went out in his 35 ford. went over to his place he had the car on stands and the rear end and torque tube out plus trans was unbolted. question is does the trans remove from the rear or do you have to pull the motor? if you have to go from the front can you just loosen the motor mounts and jack the engine up or do you have to pull it? thanks in advance
