George/Maine
I realy don,t think you even looked at anything.
As I understand it, for earlier drums, I'll have to change hubs. I'll need the hubs, then a bearing spacer for the new hub. Regardless, I know I'll need the spacer that goes behind the wheel but IF I can find a decent set of drums, it is simpler than changing out hubs etc.
Hubs are roughly 140 apiece. Drums 125. Pretty soon you're up $600+.Also more to change out and sometimes "fit".
Trying to avoid reinventing the wheel so to speak.
I couldn't measure ID but I could do the depth
Take it to a shop with a drum micrometer. I am not sure what to do with the measurement you are taking.
Charlie Stephens
I am not sure what you mean. All you need is the right hubs (early or late) with the drums to make things work. Once they are bolted together they will interchange as an assembly. Note when I say bolted I mean with studs correctly installed with a 20 ton press. My guess is that with a little looking you should be able to find a good hub/drum assembly (less than 12.040) for about $100 (comments anyone?).
Charlie Stephens
As I see it then, an option is to install something like some Speedway early Ford hubs along with early style drum ? Or find 46-48 drums, clean up, change bearing and install.
Thanks for hanging in there with me guys.
You left out finding good pre-war hub/drum assemblies. Go slow on changing the bearing, a lot of the old bearings are better than the current imports. Clean and repack. Remember not to spin the dry bearing with an air gun or it will damage it.
Charlie Stephens
I should have taken a picture of the Mexico label on the bearings in there now. Oh well ,Fords are made there now anyway ? Many years ago i was spinning a bearing with an air gun and the shop owner explained what was getting ready to happen........
.......Drives OK but I'm now trying to find some one who can dynamically balance wheels.
