35/Cabriolet B pillar
FLATHEAD TED .......................
Just what are you calling the "B" Piller ? If I can photograph mine, I will do so.
MIKE :)
The B pillar would be the pillar where the 1/4 panel and door meet would it not? Inquiring minds want to be sure. lol
Yes A = Cowl to Running board .B to 1/4 panel and door meet .Your onto it Lawson,On 34s there is a L casting bracket from the pillar to the floor .or at least on Roadsters ,Thanks Mike if you can photograph it.By the way Mike what holds the centre pillar on a 34 Phaeton ?? is there a T shaped one .
on the 35 Cabriolet there is a very thick and large casting (spade shaped) at the base of the B. there are two carrage bolts one into the top of the body mount the other into the top of the frame.
Here's a low res photo taken off the internet a while back.
Flathead Ted ........................
I could not photograph the support in my '35 Cabriolet. It is completely covered up.
I was able to photograph part of the support in the '34 Phaeton.
MIKE :)
Ted,
I am away from my car until the weekend, I can photograph the bracket and will post it then.
Gordon.
Ted
Sorry for delay in getting these up.
Two photos of bracket, unfortunately seat sides are in the way ,hopefully they show enough to be of use.
Gordon
Ted,
I aint got the legs for a kilt, their best feature is that they reach the ground.
Say Hi to uncle Charlie.
