35 Battery Cable Grommet
Should be 2. There are 2 brackets that are secured to the top of the bellhousing and extend upwards .They go in the hoops of those brackets. The cable passes thru them from the starter switch to the starter.
433487
Here is an excerpt from the 35-36 Ford Book showing the rubber cable sleeve and special plug/stud that holds the rubber sleeve in place. Both are located on the back of the engine block near the oil sending unit
