The alignment on my 34 PU door is fine in the back but a little low in the front. I have tried moving the hinges up as far as possible but as you probably know there isn't much if any adjustment. I have aligned the back on previous trucks with shims under the cowl but this doesn't seem logical for this situation. Any tip in aligning this would be appreciated. Thanks to all.
