It depends if you are just sticking a handle on to crank the window up or down yes they will but for continued use they will fall off due to lack of attachment.
The handle you show are a 37 and what appear to be two 38's. They will fit the 34 pu shaft but these handle attach with a roll pin. To install them on your pu shafts requires drilling a hole to index the retaining roll pin.
Correct 32-4 pu handles are of a different design and are attached via a screw that retains the handle thru a hole drilled in the the crank boss head of the handle.
I purchased mine from Mac's for my 34 pickup they are good quality, however you will have to modify the head of the retaining screw on the door handles as they were drilled a little off center & too small, the window handles were ok. Typical of imported parts.
macsautoparts.com Are you keeping your 34 pickup stock or street rodding it? Could you post a picture or email me one ?
Thank you, Gary.
I looked again and they are made on China .If you try and fit the original screw the head is to big, but they come with a new screw ,So why not use it most people would prefer a new screw it fits perfect ,[/QUOTE .Typical of imported parts.??
Hi, I'm trying to politely answer your question regarding door handles without making this a sales pitch but since I originally answered and you were directed elsewhere with no results let me comment that I have the door and window handles in question in stock with the correct mounting screws.
It would be nice if the Venders could advertise on a venders list /page .like it used to be .
I do advertise and support Ford Barn! Big ad on home page right under editorial. This is a forum setting and not an area to conduct business. see phone number in ad.
