First Model A try
New member
Just got a 34 3 window but learned it is sitting on a 35 frame.
Rear end dimensions are close enough (will use triangulated set up) BUT the front has me concerned. Will be going fender less, using 4 bar front and either Vega box or Unisteer.
Does it matter that the 35 frame has front axle behind the spring and the 34 axle is directly under the spring? Thanks for the help.
