BB Bfowler
I am neck deep into my truck project and I am finally at a point where I would like to start putting things back together, but, I have lots of questions
There are are different styles of grease fittings in various places on the truck. Is it because they were intended to receive different kinds of grease? I was planning on swapping them all out for new ones and pumping them all with the the same kind of grease. Is this a bad idea? Is there a specific grease that I should be using on the chassis?
Rear Diff - 600wt oil?
It has a 4sp transmission w/ PTO what gear lube is recommended?
It has, I believe, a 1937 V8 - best oil? Unknown milage on engine
There is a oil hole on the distributor cap - motor oil?
The truck came stock with a V8 in 1933, that is not the engine that is on the floor of my shop. The engine is, I think, a 1937. It appears that someone at some point, probably during the engine swap. put a 1" pipe riser on the engine mount in order to get the water pumps hoses to clear the front cross member. Is this normal? Is this a common modification? Is there an off the shelf engine mount that will raise the engine up enough to clear the cross member? I am figuring that I will fabricate and weld an extension onto the old engine mount frame tab. good or bad idea?
Steering/tie rod end rebuild parts - all metal or the plastic/teflon ?
I think I will be running a new wiring harness - can I get one for a 33 BB? recommendations for a harness supplier?
I would like to run a slightly taller tire it has 6.5 - 20 tires now, has anyone had problems/issues running a taller tire? I will be using this truck mostly on dirt roads in the Sierras and would like to have better roll over if possible.
Those are my questions for now..
Many thanks in advance!!
Brendan
Nevada City, CA
Brendan
Nevada City, CA
