Halftracks
I have an original 32 v8 block that I'm putting back together. It has a later cast camshaft with the press on fiber cam gear. The block has been machined for cam bearings. I have a harmon Collins 3/4 race cam that has been waiting for the right engine to come along if I can use it then I can use a bolt on aliminum cam gear. but I find out now the crank gear is also diferent. It still has the original 32 forged crank in it. Can I pull off the crank gear on that early crank and install a later gear to work with the alluminum cam gear ?
Thanks
Ed
Thanks
Ed
