Strick
Is this a 32 Ford V8 Motor Mount? Reason I ask is I have an original 32 chassis that I'm putting a 8BA motor in and when I hold the mount up to the front of the block, the horizontal leg with the oval hole comes no where near mounting the biscuit to the front crossmember...It falls way short.
Original K-member is still rivited in. Using 32 unsplit wishbone. Front crossmember is bolted into original rivited holes in frame. Everything lines up so no questions there.
Thanks in advance for the assistance.
