32 Ford Dual Windshield Wipers
Terry McHale
New member
My 32 5W has dual windshield wipers which appear to be original. Most of the 32's I see online have a single wiper and only occasionally do I see one with dual wipers. The reading and research I have done does not explain whether this was offered as an option or only on certain models or maybe during a certain production time-frame. I'm curious what the logic is behind the single/dual configuration? Has anyone some information on this?
One wiper when the car left the factory. Someone added the passenger side wiper at a later date.
I don't remember seeing the dual wiper set up being available for the 1932 Ford but it was an authorised Ford accessory ( at extra cost) in 1934 and could be easily fitted to earlier models. It is shown in the 1934 Ford accessory brochure. Regards, Kevin.
The dual/tandem accessory wipers for the '34 Model year utilize just one wiper motor (vacuum) with the wiper arms/blades connected with a rod between them as seen in this kit. >
I don't know if this kit was offered in 1932...
Mine has a separate, original type, wiper motor on each side, working independently from the one on/off vacuum switch. The replies that I have recieved indicate that this would have been added post-production. Thanks to all those who supplied information.
Here is what Ford Did offer as a dealer installed accessory. The opposite side wiper attached the the driver side with a link. It keeps them in sequence with each other. I don't think Henry Ford would have like the wipers moving back and forth not in parallel. Pictured is the brochure and the kit itself.
Bill Monzo
Dual wipers on our 32, and the accompanying picture, though grainy, shows the mounting of both the motor and the attaching post mounts.
