32Gnu
Questions again..
I have the 8ba in the deuce and the crank pulley is not going to clear the crossmember.. The engine is against the ******, not yet bolted (lacks 1/8") and also against the firewall because I cant drop the engine down to the mounts because of the pulley...
I really dont want to cut anything do I need to get my 59a pulley and bolt it on?
Take a look at the picture..
Also I am beginning to wonder if either the frame is not the correct frame or my pedals are not correct becaise you can see where the frame was cut with a torch to get the clutch pedal installed.. I will post a pic of this later.. I gotta go put a headliner in my Che#y... Thanks for the help// Tom
