Say I have been helping the brother in law out trying to ID two engine blocKs. The stampings are the same on both ECZ-C and the heads are stamped ECZ-G. One has a slightly smaller bore than the other, can not seem to get a straight answer from the books. Anyone know if these are 292's or 312's? PS. also the crank is stamped EC and then the drilled hole is there. Thanks
