I'm sure someone always says make it "perfect", but are these really worn enough to justify (rivet) removal, welding, grinding etc. for this amount of wear? (I'm making all clevises etc tight)
The instructions are to weld them up and file them flat. Given that they have to be accurate within a few thousands, that may be problematic. It would require a lot of file to fit. Measure the brake shoe concentricity to see if you got the tracks right.
The Flat Head Ted kit allows the brake shoes to float which takes the roller tracks out of the picture.
