My 302 has to have starter removed to see the numbers.
My friend has a 1991 Ford in his car has a carb on it trying to find a camshaft for it he wants to go roller but no one can tell us for sure what cam will work for his block cause in 1989 to 1999 they use the same blocks we were told but in 1993 they had roller lifters most of the block were set up for roller lifters
So can we fit a retro fit cam in it cause it is the one he only can find that he likes
Couple pictures of the blocks one a roller block one a none roller one
First one is the roller one
When ever I deal with cams, I like to talk to the people that either manufacture the cam I want to use or I talk to a person that has a cam grinder and can make any cam profile I want on a cam that I have. Those are the type of folks you need to talk to. Be sure that you know that the block you want to use is a block that was made to accept rollers. It's better if you have the part number to cross check it for certainty. Ford made so many of those 302 blocks for so many years that I'd want to know exactly what I have.
I/m not a giant fan of roller followers anyway. I've seen some fail and it ain't purty.
Also, you can get a tie bar lifter which keeps the lifters aligned and allows a larger selection of cam profiles.
Dave
So does Chevy
OK, Thanks. I was thinking before factory roller cams.
Sal
