You have the best of the overdrive transmissions: a T85 with the R11 overdrive. The T85 and T89 shifter covers interchange. Most of the T85s I have seen have T89 covers on them. The T89 had straight cut first and reverse and never had a main shaft for overdrive. The T85 had helical cut first and reverse gears and could be had with or without overdrive. If you purchased a blown Studebaker or Ford with overdrive, or purchased a big block Ford or Chevy with overdrive, you got a T85 with R11 overdrive.
These were side loaded, not top loaded.
