Depends on the parts you have, if you have the cowl and dash, that will date the body, this one is pre' '26 with the rectangular dash switch hole.
A car chassis of the '23-'25 years could be used to fit this body, with the body mounting brackets modified to relocate them to fit the frame to body brackets on the car chassis.
An open car firewall of '23-'25 would be used, and later high radiator and hood should fit your cab cowl, if no cowl or dash, then you can fit which year parts can be found.
