1966 289 no start
why not disconnect the fuel line before the pump(cap it off) and empty the carb. then dribble some fuel in the top of the carb. If you have spark it should start, but briefly. If it starts then rebuild the carb as now you know it's a carb problem. water, moisture is another thing
I believe I found my issue, never seen a timing chain so loose you can almost flip it off with a screwdriver.
That's definitely "a" issue. It might be interesting to see just how far off (late, or retarded) the valve timing might be. N.b., this is different than ignition timing.
A quick & dirty method is to roll the engine over by hand slowly clockwise 2 complete revolutions and stop with the pointer on the "0" TDC mark. With the distributor cap removed, now slowly turn the engine counter-clockwise while observing the distributor rotor. As soon as the rotor starts to move, stop turning, and note how much "slop" there is measured in crankshaft degrees.
I placed it on TDC and it had jumped a good bit . My grandson and I were trying to start it and it tried to start then made a noise and this was results .
... damn ...
That explains the no start.
The fuel pump is driven off the camshaft and it is still overfilling the carb fuel bowl with the stretched chain. I think she still wants to live ... :eek:
:confused:
Forgot to ask, does the cam gear have nylon teeth?
