KULTULZ
- A MUST READ -
1956 LINCOLN CONVERTIBLE - https://www.hemmings.com/stories/article/luscious-lincoln-1956-lincoln-model-76b
Can anyone help me out with info on a starter motor replacement for my 368 LYB
Will a 292 /312 y block starter fit ?
I see your plight ...
EDIT -
Do you by any chance have the old starter out? If so, do you see any ID NOS on the case?
I do have it out it looks identical to a Yblock one but I can’t find any ID number
STARTER, REBUILT, 12 VOLT, 5.75 INCH SHAFT, 3 MOUNTING EARS, LESS BENDIX
Manufacturer Reference #'s: 93501, FAR-11002-A, B6A-11002-A, FAR-11002-B, C3NF-11002-E, PB6M-11002-A
- A MUST READ -
thanks for your helpThat's OK ...
From what I can decipher in the old MPC(S), they are not the same. But NDP gives a listing using either ENGINEERING ID NO. -
Both used the same starter drive.
Maybe give them a call for clarification. I hate to give you incorrect info.
https://www.npdlink.com/product/starter-rebuilt-12-volt-575-inch-shaft-3/159929
I never worked on one as they were considered rich man's cars ...![]()
... i would like to try adjusting the rear band, my question is: is there the hole to access on the floor pan to adjusting it ?i saw on my manual shop for 1958 is there but 1956 i don't find
it, does anyone knows about for that ?
