E elmo771 Member Mar 26, 2025 #1 Is there any difference on a 1956 6 cylinder and a v-8 cylinder frame mount cradle
E elmo771 Member Mar 27, 2025 #3 1956 Customline, the frame piece with the 2 holes for the motor mounts.
KULTULZ Well-known member Mar 27, 2025 #4 The 1955-56 FORD CROSS-MEMBER ENGINE FRAME MOUNTS are the same. Attachments ENGINE MOUNT - 1955-56 FORD 8 CYL - FORD MPC ILL - 49-59.pdf.jpg 11 KB · Views: 14 ENGINE MOUNT - 1955-56 FORD 6 CYL - FORD MPC ILL - 49-59.pdf.jpg 11.6 KB · Views: 16
56sedandelivery Well-known member Mar 27, 2025 #5 55-58 6 cylinder B7A 6038-B 54-58 Y Block B7A 6038-A
KULTULZ Well-known member Mar 27, 2025 #6 Now are we describing the flange mounting brackets welded to the engine mounting cross-member or the actual insulators? Attachments ENGINE MOUNT - 1955-56 FORD ENGINE MTG CROSS-MEMBER - FORD MPC ILL - 49-59.pdf.jpg 20 KB · Views: 11
56sedandelivery Well-known member Mar 28, 2025 #8 I would think they are the same with the engine mounts being the difference. Mine originally came with a 6 but now has a V8. But my mounts are custom made as is non original V8.
KULTULZ Well-known member Mar 28, 2025 #9 elmo771 said: The flange mounting brackets on the crossmember Click to expand... The actual flange(s) itself is the same as there was no separate 6CYL or 8CYL frame released. The cross-member itself is a part of the complete frame assy. The difference is in the insulators and 6CYL block mounting brackets on the 6CYL.
