1956 engine mounts
The 1955-56 FORD CROSS-MEMBER ENGINE FRAME MOUNTS are the same.
Now are we describing the flange mounting brackets welded to the engine mounting cross-member or the actual insulators?
  • ENGINE MOUNT - 1955-56 FORD ENGINE MTG CROSS-MEMBER  - FORD MPC ILL - 49-59.pdf.jpg
I would think they are the same with the engine mounts being the difference.
Mine originally came with a 6 but now has a V8. But my mounts are custom made as is non original V8.
The flange mounting brackets on the crossmember
The actual flange(s) itself is the same as there was no separate 6CYL or 8CYL frame released. The cross-member itself is a part of the complete frame assy.
The difference is in the insulators and 6CYL block mounting brackets on the 6CYL.
