I want to remove and then reinstall the springs before the engine is installed. My thinking is change bushings and springs, install disc brakes and all of the power steering, and then install the engine. Should/can I leave the springs compressed and adjust the tension to keep the control arms in the correct position without the weight of the engine, or should I release the compressors and let the upper control arm bumper rest against the stop until the engine is reinstalled, I don’t know if this ruins the bumper or not.
