Can get the motor to start and run start and run, don't have a generator what size belts can I run water pumps just to cool it will that work at all thanks
If you just want to run it for a short period of time, run it till the temperature reaches the level where the thermostats would open and allow water flow.Thanks for responding. Reason for running it this way I don't have a generator just installed it in my 49 F1, don't know what kind of shape the motor is in want to run it for a little while just because you understand. I have a flathead radiator all hooked up plumbed everything is good to go just no water pumps turning at the time thanks
I was trying to add pictures but I haven't figured that out yet
