No filter, it's more or less a direct connnection to your lighting circuit. Chech your connnections and yes you could remove the panel. The bulbs are not in series so one bulb would notg effect the other. Unless the circuit to the dash has a bad connection. Check also your grounds the for the dash. When you remove the panel you will have to ground the panel get the lights to function.
