Mine is dash mounted so removal is simple. I have never removed the column type but there are other threads on this. Try the search function, you should find lots on this.
If it has the original just pop the spring loaded stainless cover off the front, then push pull the ignition switch toward you and turn it which unlocks it. Then you remove it from the back. Hope this helps, Dale.
