What "51-Merc" said is probably the best way to go and will work just fine (unless you have loaded the car up with electronics and a 100 amp alternator). If you really want to change to a voltmeter that matches your existing gauges, the short answer is "NO" I suppose you could have one custom built for a ton of money. The fact that your car is a Mercury makes things even tougher.
