cabrioletgalaxie
A bit more work on the problem today. Checked the hot terminal on the ignition switch body and found 2 of the 3 were very hot with the switch in the on position. Tested the condenser and found it to be good.
Used a test light to learn the points were opening and closing and then took off the distributor and confirmed that. They did look a bit over heated.
Finally we tried to find the ballast resistor thinking that could be the issue of the ignition switch over heating. But we could not find it. I found a tiny aluminum box on the upper inside of the firewall. It was 1/2" by 1 1/5" long. It did not look like a resister but that's the only thing I could find.
Can someone tell me where to look for it?
That's where we are at this point. Not much closer to a solution.
I ordered a new ignition switch body on the off chance there could be an internal short.
