some times the rubber line between the fuel pump and the steel line to the tank can get rotten inside and look good on the outside. even new ones if they are not of a decent quality and immune to alcohol. rubber falls apart, and/or it can collapse when the pump is trying to suck gas. take the line off at the carb and crank the motor over with ignition off and pump a bunch of gas into a quart jar so you can see what you got and how good it pumps
