Barry53
I am putting back together a 39 ford pickup, on it the hood hinges are triangle shaped with two bolt holes at the front and one at the back. At the front of the hinge is a right angle piece with a bolt hole thru it. Depending on which side of the pickup I put the hinges, the right angle piece can be at the top or the bottom of the hinge. Hopefully some one can follow this. Now presumely the side panel bolts straight on to this backet
