Conrad#Hamburg
Hello from northern Germany,
I am rebuilding my steering gear with the set from the early ford store.
I pressed the new worm gear onto the shaft, but then I saw the housing for the cross shaft? has also two wheel bearings that have to be changed. Do they also go out with a hydraulic press? And from which side?
See the pictures I added. In the books that I have it is not written.
Thank you guys,
Conrad
Thank you guys,
Conrad
