Bruce Lancaster
With so little push going on I would next look at the front plug of the main tube. If it is missing, from a friend's experience it results in about what you are seeing...the barest trace of pressure, in his case enough that no damage resulted.
With long type pump, I don't think you would have priming troubles.
