allenmichael
I've read all the posts on the ferrule and about not overtightening. New nut and ferrule , all good with only 5 gallons in it. then with 10 gallons , leaks around the line itself from the fitting. appears the onion is not set. have tightened slowly tested, leak, repeated. still showing threads, last turn had a bit of a "screech" which I thinkmight be the ferrule spinning a bit? I have not tried vaseline on it between the nut and it. frustrated as all get up. oh and this has a steel line. nut was turning slightly in a herky jerky fashion with moderate effort, before the screech. Should I crank it down tight or use vaseline or both?
