- City
- Riverside
- State
- CA
- Price
- 1,300
Super rare 1936 21 stud Ford LB flatty! This is the first engine with insert bearings but still has the early water pumps so it can be used in an early car without changing the stock look. It looks to be a good builder and will probably turn over but I have not tried. It is a standard bore engine so it has never been messed with. The only issue I can see is a small crack coming from one of the water passages. Im told that is a common problem with these engines due to overheating and a good machine shop can easily fix it. It is stamped LB and then CS underneath. it also has a series of number and say's CAL so I assume it was made in california. I have more detailed pictures if you need to see them. email me your address and I will send them over. Asking $1,300 OBO Thanks! Kevan (714) 924-2249
