BlueSunoco
'A simple job for simple people' Quote from Curly, Three Stooges, A Plumbing We Will Go.
Pretty straight forward, right? I was changing a bulb that blew out on the high beam side. For four hours. I never did get it put back in, started losing my patience quit and walked away.
I don't fault the design I blame the cheap a++ Vintique parts that were used for the assy. What a pile of dog doo doo.
Is there any trick to trying to hold it all together, the reflector on to the three little brass studs that hold the reflector and bulb in place? And then get the bulb onto that afterwards? It is really hard to get the bulb on to twist it to lock. With original FORD parts it would be a two minute maybe three minutes top to do this job.
Any suggestions much appreciated. Thank you
