1936 choke and throttle rod length
Alan, Here is a dimension sheet showing the dimensions for a 36 choke and throttle rode for your cabriolet. Don't worry about the design of the knobs.
Don,
I can't quite read the writing in the picture. What is the amount of offset that needs to be bent in the rods? Also, the 30.76" length for a model 720... is that before it is bent?
The reason that I'm asking is because I'm having to modify some rods from a Ford tractor. Apparently these parts aren't made for a 36' Ford any longer.
Have you tried downloading Don's illustration and then enlarging it on your computer? If you do that you should be able to read all of the writing.
Here are some details from Don's drawing which you should be able to read. The overall length for your application is 30.76".
