MIKEV3550
Hello, I am working on my mechanical brake system on my '35 car and in looking at the clutch/brake assembly there is a lot of play in the assembly. My question is, I'm not sure how to get it out of the car. I have the floorboards out but the engine and transmission are in the car. I hope I do not have to take the transmission out to remove it.
Wondering if I need to knock out the pin on the shaft by the brake pedal and then the clutch pedal will slide off the shaft and come out of the hole on the frame ? Looking for help...
Also looking for 2 front brake wedge studs that go through the brake wedges.
Mike.....
Mike.....
