Ghost of elmirage
This is some good advice. Those mechanical brakes were designed to work just fine as long as they are taken care of and adjusted properlythirt4 - Depending on how much you use your car, mechanical brakes might be just fine.
If you use the car a lot, hydraulics would be a reasonable choice and could be done by "re-arranginf" Ford parts. However, if you use the car very sporadically, the mechanical brakes might be a better choice because the hydraulic system is subject to internal corrosion if not used/heated up regularly. The heat from usage drives out the moisture. FWIW
