1933/34 and 1935/36 Rumble Hinge Bracket
tsbrock
Does anyone know if the 1933/34 rumble seat hinge BRACKET (the part bolted to the body... not the lid) is the same as the 1935/36 hinge bracket? Are they interchangeable?
Three pictures attached.
1. Shows the location in the rear of 1934 Roadster where the hinge bracket mounts to body
2. Shows the hinge bracket for a 1933-34 rumble seat hinge system
3, Shows the hinge bracket for a 1935-36 rumble seat hinge system
The two brackets for the 1933/34 and 1935/36 look so similar.
Note: I pulled these pics off internet to illustrate my question... hope that is ok.
483986
483987
483988
That part (call it a trunnion for lack of better description) is used on 1932 3 Window, and 1933-39 with rumble.
In the past we made them in aluminum. I recently made a half dozen as a test run for a steel rumble hinge kit for the 1932 3 Window, I will be making more but it will be at least 6 months.
