How tight do you tighten the two threaded rods that come off each leg of the stainless trim on the radiator grill shell? I want to pull trim down tight to the grill shell but don't want to break the threaded rods by over tightening
My trim has a small hole at the center of the horseshoe loop that aligns with the radiator inlet hole of shell. Is there supposed to be a small bolt or screw there? If so, what type bolt or screw should I use?
