1932 Ford Floor Board
WRA
Ok, maybe I’m not doing the search correctly but I’m having a tough time finding what I’m looking for.
I’m installing some wood floor boards in a stock 1932 Ford. I’m interested in some pictures of originals. Here is couple of the specific items I’m interested in.
1. Pedal & Steering seal, along with top and bottom metal plate installation
2. The clutch T/O bearing cover on the toe board, what does it look like and what is proper name so I can look for one.
3. The parameter seal, was this held on with tacks, or staples of some sort.
4. Finally color, any recommended stains or paint.
Thanks Fordbarn
Article by Dave Cole attached
Glenn
  • 32Floorboards.pdf
    32Floorboards.pdf
Note that in Dave Cole's excellent article only one of the two versions of the upper and lower pedal plates is shown, namely the later version which reflects the shortening of the brake pedal as a running change with a much deeper notch for the brake pedal than for the clutch pedal. In the early versions, the notches for the brake and clutch pedal are the depth in the upper and lower plates.
