Nate,
Good pictures to start to document what you have, where your going, and where you have been, on the 32 dump truck project!
You have the A team working with you. It will take some time but you will get there. I did not see a picture of the carb side of the engine, or missed it. Do you have the distributor? Fuel pump?
Regards,
Chris
Chris- I don't believe I've posted that side of the engine; lets fix that! I do have a distributor and fuel pump. with some of the other components on this block being wrong already, I'll post both fuel pump and distributor to check for correctness. (Distributor has $8 sharpied on it so I am sure its been replaced and with other A parts being put on it very well may be different than what I need)
I hadn't planned on any work today on this old truck, but as one does, I found myself in the garage after the family cookout.
finished getting door hinge pins install, got all wheels off without much trouble and got front hubs off before kiddo went down for the night. rears are a little tight and may require some percussion mechanics to free them- for another day when little eyes aren't closed. ( I abide by the "let a sleeping dog lie" carefully with young children) Found AA drums, and brake material/ hardware to be in good shape, will adjust once back together.
If you haven't put the new head gasket and head on, then it would be a very good idea to pull the valves (obviously keeping track of what goes where), and inspect the valves faces and seats. Given that the engine sat for a long time, there may be rust on the ones that were open. I'd clean them well with some steel wool, inspect carefully and determine if any need to be touched up. If they all look good, then get some fine lapping compound (not coarse!) and lap them back in to ensure a good seal. This is not a big job (if everything is not rust pitted) and you'll know that all your valves will correctly seal. Now is the time!
Bored&Stroked- this exact topic came up today with my grandpa. I had the Intake valve on cylinder #3 soaking in 50/50 and it kept wanting to stick slightly, with no luck as of today and this is the grungiest part of the engine as it doesn't look like it was touched in the "recent" rebuild. This has bothered because I would be a ripe fella to have to take it all back apart if it didn't work as it should when I was already this far in.
Conclusion: A model A friend with deep machinist background has agreed to do a proper valve job on this engine much better than grandpa and I feel we can pull off; I think this will complete the rebuild. I will also see if he will check if both head and block mating surface is true flat while he has it. I'm told I will "**** myself" when I walk into his shop.
with that said; this engine is now getting pulled. while it is out I'll be replacing the ring gear as there are about a dozen teeth with some damage and will have a good opportunity to take a look at clutch/ throwout bearing/ etc.
any other recommendations for Bill to check while this is at the machine shop??
thanks all for checking in and keeping me out of the weeds too much. everyones recommendations are taken seriously into my decision making on this project.
