David,
These dump truck guys have to stick together! The few, the brave, the ........ Ok just went off in the weeds!
I believe Nate is looking for some big boy wheels and lug nuts too. Anbody out there? I lost my lead from a year ago for some wheels in Mich. I didnt really need them so I passed on them. WIll try to pick up the trail again.
Nate I know some one that might be able to make some seat frames, Not show quality but might work for you. Springs from Snyder's worked for me. They can build custom springs too.
Will be interestd about your dash gages? None of mine function at this time but it really doesnt slow me down any. Amp gage is superseeded by a volt meter. The spedo cable is not in the truck and the 90 mph is probably not the right one anyway. Only have to worry about speed in a school zone!The gas gage, way over my head in complexity, so I just pop the seat off and look in the tank.
What was the original color of your truck?? Find paint inside the cab??
Regards,
Chris
I'll check to see if I have any usable wheels.
Amp gage United Pacific 30 amp gage-I put it inside the '32 mount- good fit. Newc
David,
I have slept a couple times since then, do you have that extra gas tank side frame or do I have it? If you have it and want to bring it along for Nate, it just might match his tank??
Nate, well there go on the wheels. Awesome KDL!
Regards,
Chris
Chris,
I have it and will bring it along in case it fits his tank.
I took the transmissions top-plate off to take a look, pictures below. looks to be in pretty good shape, some wear on one gear, which one I am not sure maybe third? I do not claim to be a transmission guy. I do have some slop in the shifter, seems to want to spin in the cup about 30 degrees rather than slide from side to side in neutral. any recommendations to try and tighten this up some?
Nate,
Rear hub pulling.
I have some pictures of the old puller I used. In my thread near front??I had to open the holes a little and I had to get some left hand nuts and modify them to get max thread engagement. A real good grip on the threads is important. I almost damaged a stud because it was not on far enough. These old pullers were on the web for sale.
Your trany looks as good or better than mine
I did tune up on my shifter to reduce the rotation in the shift lever. It,s all from wear. The pin, the socket have wear. All rebuild able with care. Just had my shifter out today trying to improve it too.
Remind me and we can review the things I did to improve my 60 degree shift lever rotation!
Regards,
Chris
