1932-34 Model B Four Cylinder Group started!
My car is now a member of this group. Have over 10k miles on the B engine in my 31 Slant-windshield model in the past 6 yrs. Just finished a brake job last wk. Now to do some motoring.
Someone help a newbie that doesn't know the differences in A and B engines, and loves the sound of "more power"...araghhhh.
A engines were used in the Model A from 28-31. They are gravity fed
B engines came in 32-34 Models they have a fuel pump and many "improvements" that make them rated at 50 hp not 40hp like the A. There are lots of differences between them I'm just giving you the Cliff Notes. The search button and Google are your friend if you are interested in a more detailed answer.
I'm in! looking for more stock and low key builds rather than the way out hotrod motors on the Bangers threads on HAMB.
I'm working on my 31 deluxe roadster with a B engine.
I would like to join as well. I have a BB dump truck and building a 28 roadster with a B engine and ******. Is it difficult to drop a b engine and ****** in a model a frame?
I like that homemade up/down draft intake.
I'm not sure if I'm going to use it. This engine was assembled in the late 50's and never run. I bought it from a guy who recently acquired it, took it to a machine shop had it disassembled, tolerances checked reassembled and run.
Let me know if you don't. I'm always on the look out for homemade hop up parts. That motor has some really neat details on the outside. Whats on the inside?
skryla,
Can I stop by while I'm down around exit 83?:D
Keep 4-banging!
Sure Jersey Boy. I am exit 89. I will be working on setting the 32 front end in the 31 this weekend. Parts are growing all over the garage!
i have a B motor with a BB crank , light flywheel v8 cluch 32 transmission ,mitchell gear splitter ,down draft 1 bbl glass bowl holly carb .in a 30 sedan. been runing it for 7 year now . got a few B blocks a few have been welded up i welded 1 up at the back by the firewall, could not believe how thin it was . i think the castings are thiner then the A blocks
I had some success over the weekend. Got the 32 axle under the 31 roadster. Once I get the brakes, drums and tires on, it will be time to put the B in.
So who has a good crack free diamond B block to sell for a new salt engine , Needs to be in CA,, AZ , area, only need a block & one i can afford. mail me direct , Thanks,
