1931 Roadster Windshield Brace
1955Buick
Just got a 1931 roadster trying to figure out if there’s an aftermarket product that can brace the window open. I would like to be able to get some fresh air in the car with the window open a few inches, but it keeps being pushed down by the air as I drive. Any help or pictures would be appreciated if you have an idea.
Thanks
Bob
Bob, The closed cars have sliding brackets with notches to prop open the windshield. As you’ve found, the Roadster lacks these, and you can’t tighten the nuts enough to hold the windshield open, either. I’ve taken to putting a rolled up microfiber cloth under the corners to prop it open. If you look closely at the picture of my Wretched Roadster you can see the yellow cloth. I tried using just one cloth placed in the middle but got lots of vibration. You’ll also notice you’ll need to re-aim the inside rear view mirror as it is mounted on the windshield frame and pivots down as the windshield is pushed outwards. I modified the bracket to allow the windshield to be pushed out further while still using the mirror. This is only partly successful because when the windshield is open enough to let in a lot of air the frame jiggles so much the image in the mirror becomes too blurry to be useful. Instead I rely more on the outside rear view mirror.
I hope someone has figured out how to sculpt a piece of wood or something that can hold it open far enough to be useful and keep it from jiggling so much.
This is what I rigged up for my Roadster. If you think this would work for your issue let me know and I can get the you details on what I used
527268
527269
527270
It's a 2 inch stainless brace strap that I drilled out on the post side for a 5/16-24 x 3/4 stainless bolt. I doubled it up to make it more rigid
The other side is a M6-40 stainless wing bolt (I could only find these in metric sadly) with a rubber cap. I drilled out this side of the stainless brace for a M6 nutsert.
I have extra stainless braces and rubber caps. PM me your address and I can send you those parts
527268
527269
527270
Yes that looks pretty good. Did you have to drill holes in the windshield post?
Send me the details of how you did it.
What parts would you be sending?
The hole in the windshield post was existing on my A. I have the Deluxe windshield setup. Not sure if it is there on the Standard.
I have some left over stainless bracing straps and rubber caps I can send out if you want to attempt doing something similar to what I did.
Is there any tendency for the frame to twist with the support on only one side? Can be a lot of force on the windshield at higher speeds.
