1931 deluxe roadster package tray
gdmn852
Hello, can anyone post a few pictures of the package tray are on a 1931 deluxe roadster? Currently working on this area, redoing and older restoration. Think I am missing a windlace piece that goes between top of seat and tray .Also seen fasteners for top boot? In this area. Thank you.
The panel behind the seat is a two part set up. There is the main part that attaches under the belt wood and then there is the seat adjuster part that completes the structure. This link only give a small amount of insight but it's something.
https://www.snydersantiqueauto.com/product.htm?pid=976388&cat=0
This link is the other panel that fits with it.
https://www.snydersantiqueauto.com/product.htm?pid=976390&cat=0
The whole thing is covered with material. B Terry has some good photos on his site where the trim is being installed. You could ask him what is used to trim that area
Hello, thank you for the reply, did check on B Tarrys website and some pictures were helpful. Vol 6 of how to restore your Model A has a lot of info , if I could find my issue.Snap fasteners on inside must be for top boot,
This is the package tray done by LeBaron Bonney on my 31.
Hello, thank you for the pictures, I assume interior in my car is a Lebaron Bonnie also I see now that a flap of material they had tacked to back of wood seat frame should cover the flat part of the package tray, also screws go through the bottom of package tray to hold angle on back of seat . What I also thought was a piece of windlass is actually part of the back upholstery. Thanks again, might get this thing done before summer is over.
