L lincofish@charter.net Junior Member Mar 24, 2023 #1 Hi all. Can anyone tell me what goes into the large hole in the rear spare mount? Thanks.
W wrndln Well-known member Mar 24, 2023 #2 The "D" nut in the bracket is probably missing. The "D" nut is on the top of the bracket. I had to install a D nut on one of my rear spare tire brackets. D nuts can be purchased at most model A suppliers.
Oldbluoval Well-known member Mar 24, 2023 #3 Upper bolt goes thru the small upright support which is part of the lower panel assembly The lower rear sill has two large d-nuts as eluded already
midgetracer Well-known member Mar 24, 2023 #4 The upper bolt goes from inside to the spare bracket using the path Oldbluoval said.
