1930 Roadster spare mount
The "D" nut in the bracket is probably missing. The "D" nut is on the top of the bracket. I had to install a D nut on one of my rear spare tire brackets. D nuts can be purchased at most model A suppliers.
Upper bolt goes thru the small upright support which is part of the lower panel assembly
The lower rear sill has two large d-nuts as eluded already
