rwatters@me.com
I'm in Key West with my Model A Cab and have a clutch problem. The clutch goes all the way to the floor without disengaging the clutch. I've adjusted the trunion that attaches the clutch pedal to the clutch arm, but no joy.
I took the clutch inspection plate off and pressing the clutch pedal moves the throwout bearing but the bearing is about an inch from the pressure plate fingers, so pressing the clutch pedal all the way down barely touches the fingers.
What do you suggest? I suspect the pressure plate is locked forward somehow.
I've found a mechanic through MAFCA in Miami, though that will mean flat-bedding the model a for 3 hours.
Im not really equipped for a major repair here.
