roblesterjr04
I think he needs to bite the bullet and swap out the clutch anyway. All that grease and disk material spewed all over everything can't make for a good time.
Pulling the engine and/or trans out will give him an opportunity to inspect the pressure plate to see if its gone the way of the dodo, or if it can be adjusted and salvaged. Also a great opportunity to clean up or replace the throwout bearing.
More than a couple hours of work, but well worth the effort and learning curve, and with a good socket set and an engine crane, its a DIY job.
I've pulled an engine in a couple hours, allow for a couple hours working on the clutch, and another couple hours putting the engine back. It's a good project to spend around a case of beer and the les andrews book.
