K kb Member Oct 6, 2015 #1 Does anyone have a good picture of the original early 1929 top radiator tank with the correct hood support bracket. I am try to put together a original 1929 radiator for fine point judging and the standards are not real clear. Thanks Karl
Tom Wesenberg Well-known member Oct 6, 2015 #2 I'm out the door right now, but as soon as I return I can take a picture of mine and post it.
160B Well-known member Oct 6, 2015 #3 Hope this gives you the info you want. RG&JS 3-1, 3-2 Revised 2011 see attachments Attachments RG&JS 3-1 Revised 2011.pdf RG&JS 3-1 Revised 2011.pdf 666.3 KB · Views: 46 RG&JS 3-2 Revised 2011.pdf RG&JS 3-2 Revised 2011.pdf 608 KB · Views: 22
Dan Partain Well-known member Oct 6, 2015 #4 I think this photo is somewhere on fordbarn but I couldn't find it, so here it is again. -DAN Attachments Early Radiators.jpg 59 KB · Views: 62
K kb Member Oct 6, 2015 #5 Dan do you know which of the two pictures is correct for a March 29 car Thanks Karl
Dan Partain Well-known member Oct 6, 2015 #6 Karl, the photo on the right would be correct, the one on the left was discontinued in mid '28. -DAN
